SailNet Community - View Single Post - Deck Core replacement
post #13 of Old 01-07-2009
JohnRPollard
Moderator
JohnRPollard's Avatar
Originally Posted by zz4gta View Post
I plan to start this task next month on my boat. I'll be using balsa core and wanted to get some opinions on bedding hardware and using a liner as outlined in another post here on sailnet. I just want to make sure that a skim layer of FG is not required on the inside for strength. I plan to do the re-core from the inside leaving the outter decks untouched. (I know, I know).
I'll keep updating this post with pictures and progress. Hopefully I can have the repair done with 100sq ft of balsa, and minimal down time.
Here are the steps I have outlined
1. drop the mast and remove hardware
2. strip insides of anything important, vests, gear, etc.
3. start from the companionway and cut sections of deck out working my up to the bow.
4. plug all hardware holes to keep out rainwater, and allow a week to dry.
5. begin cutting and expoxying new balsa in place, same order as it was removed.
6. epoxy over all exposed balsa to seal it. Let it cure.
7. drill new holes and install hardware.
8. cut and install liner.
9. put the stick up.
WAAAY easier said than done. I'm not looking forward to this.
I thought you were planning to circumnavigate Delmarva this coming spring!?
More seriously, would it be at all possible to unbolt the deck and flip it over to do this work? It sounds daunting, but I think it would save you a ton of time in the long run and also yield much better results.
JohnRPollard is offline
