I have surveyed two 2002 473's both had leaking hot water tanks that had to be cut in half to get them out. Both tanks were mounted directly on a deck without airspace underneath and neither had a hose on the pressure relief valve leading to the bilge. Inside the stainless steel cover and wrapped around the aluminum tank is fiberglass insulation which acts like a big wick, hence the need for 1/2" airspace under the heater so it does not soak up condensation. Pressure relief valves often drip and without a hose the drips will find their way to the insulation resulting in more corrosion of the aluminum tank.
Both of these boats required major re-plumbing as replacement water heaters had to be located elsewhere. Other than that I found very little wrong with them.
Dirt People Scare Me
Dirt People Scare me
Reason: spelling
