1.Badger Brush a must.
2.Let dry 48 hours between coats.
3.make a board with stand-off wood screws, pointy end up to set boards on. This way you can varnish all sides at once.
4.Don't varnish out of can, and add a touch of thinner(touch)
5.Brush only on one direction, and keep a wet edge
6.Tip the varnish with brush, final brush
7.Use Interlux Schooner Varnish Only.
8.Vaccuum and Tack cloth before varnishing
9.Final Sand, the whole piece should be white sanded, I mean smooth, no ripples, smooth to the touch, and final sand should be with 400.
10.Have fun.
