Thread: Varnish Pain
  #12 (permalink)
Old 01-08-2009
Gary1 Gary1 is offline
Gary1 is on a distinguished road
David-
Keep putting on coats. You're getting close. You need to have a uniformly smooth surface after sanding. Also, use a sanding block, not the palm of your hand. Once you get the uniform, non-speckled surface, put the last coat on with quite a bit of thinner, and put on a very thin coat so it'll pull itself on nice and tight. That's the way you get good looking work.
good luck,
Cap'n Gary
