SailNet Community - View Single Post - Racor With Too Much Water??
post #3 of Old 07-10-2004
PaulBl
Been there. It does pass on through. Water will not burn in a Deisel engine. It stops pretty much as soon as it reaches the injectors<g>. You pull all the filters and re bleed the system.
This spring I had condensation and was lucky enough to drain it off on each tank in time.
PaulBl is offline
