Old 01-12-2009
sailingdog sailingdog is offline
Whatoo—
You really shouldn't be reviving a dead thread that was over seven years old to being with.
As for wiring a Uniden depth sounder to a different transducer, it depends on who made the transducer and what signal input/output it requires. Many transducers are made by Airmar, and in many cases, they can be used on different display heads without an issue.
If the wiring is the same number of wires and colors, there's a very good chance that the transducer will work on the Uniden, even if the transducer did not come with it.
BTW, you might be a bit confused, as I've never seen a depth transducer with a paddle. The paddle is for a knotmeter, and might be found on a triducer—that does speed, depth and temp... but never on a depth transducer.
I'd highly recommend you read the POST in my signature to help you get the most out of your time here. It has tips on searching sailnet, writing a good post, etc..
