Portable Air Conditioners
Ross99: I am in the market for AC. The unit you use sounds like a decent option. Curious how much water is generated from use in hot temps for like 8 hours of continuos use. The description says it has a self contained water holder that you can set up for regular draining or it will just hold all the water in its tank until filled, and when filled, the unit will turn off until you drain the water tank. It sounds like you may drain into the bilge, but curious if you know how long it would take to fill the tank in the unit? Also, could you vent the hot air out of an opening port window? How large is the unit and where do you store it while underway?
Thanks. Jon
