SailNet Community - View Single Post - Stove replacement...
post #28 of Old 01-16-2009
sailingdog
I'd second what Bubb said... pressurized alcohol stoves are a serious danger. BTW, water is not recommended as a fire extinguishing medium for alcohol fires, unless it is heavy water spray, since alcohol can burn at relatively dilute (40% by volume) levels. What can happen with an alcohol fire that you try dumping a bucket of water on is that the alcohol dilutes a bit and continues burning where ever it ends up... often burning in the bilges. With the lower amount of alcohol available to the non-pressurized stoves, you're a lot safer.
sailingdog is offline
