SailNet Community - View Single Post - Stove replacement...
post #30 of Old 01-17-2009
JimsCAL
JimsCAL's Avatar
Unless you can find the necessary parts and repair/replace the line from the tank correctly, either replace your stove with a non-pressurized alcohol stove or a propane stove. A new propane installation is going to be lot of work and cost you several times what a drop-in Origo will. Depends on how much cruising you do and how much you use the stove if the extra work and cost is worth it.
JimsCAL is offline
