Old 08-02-2004
VIEXILE VIEXILE is offline
VIEXILE is on a distinguished road
Thru Hull Replacement
I''ve probably done 20+ through hulls this year on various boats. Large plumber''s wrench inside, small wrecking bar outside (2-person job). Heat can be applied to the valve assembly flange inside if necessary. There are ears inside the exterior portion of the through hull. Once apart, take a small cold chisle and cut four notches on the lip of the through hull. From there, the bronze bends back pretty easy. No matter what you do, you''ll need to clean up around the hole, sand or grind and level it with thickened West System. On valves that wouldn''t budge, and, actually, on the last few I did just because it''s quick and easy, I just did the cold chisle thing, knocked back the flange and drove the whole assembly inward. I can now do one in minutes that way, but if you want to re-use the valve, you still have to get things apart. There''s a touch to not damaging the surrounding glass. KW
