SailNet Community - View Single Post - Bill from Channel Islands, CA
post #2 of Old 01-22-2009
CaptainFredGreenfield
Dodging Coconuts
CaptainFredGreenfield's Avatar
Hi Bill!
My Advice before your maiden sail is to run up your sails at the docks early in the morning with no wind, get used to them, check for issues.
Then choose a time when there are just gentle (less than 10 knots) of wind, motor safely out of the harbor, well clear of the jetti by quite a ways, then hoist the main, check the effects, hoist the headsail, check the effects. Make sure when you get out of the slip you haul in your fenders! If you're alone, be very cautious and make sure to have your life jacket on. Then lower your sails while at sea and motor in. Then when approaching your slip put your fenders back overboard.
Once you've given her a good solid run down you should feel pretty confident after a day of messing about... just be cautious and very slow.. dead slow... when coming into your slip.
Good luck and good sailing!
My Sailing Advice, Tips, Tutorials Blog:
CaptainFredGreenfield is offline
