SailNet Community - View Single Post - GMT's New Carbon Furling Boom w/no mandrel through the Mast
Old 01-22-2009
captmikem captmikem is offline
captmikem is on a distinguished road
in boom furling
I had a similar system on a 157 foot ketch. The Main mast was 198 foot off the water so it was a big sail. The rig was built in New Zealand and I had remotes for hoisting and furling both the main and mizzen. It was a bit more than 120K. I had two complaints with it, first the boom had to be exactly perpendicular to the mast otherwise the sail would wind up away or too close to the gooseneck. I had a little light on the boom that would glow green when it was correct but it was not accurate and we had problems with it. Also if it did not furl tight it would move forward or aft when stowed causing it not to feed correctly. The second problem was at the feeder, it would sometimes fold the luff tape and bind, I normally had to have a man at the feeder making sure it fed correctly.
In theory it was good. But in practice it caused a lot of work, and I at times wonder if it would not have been simpler to just use lazy jacks.
I used to sail an 80 foot cutter that I took around the world often with just two or three of us aboard. I had a full batten main with Harken cars and lazy jacks that were attached to the boom and were led forward when hoisting and sailing. I had hardly a problem with them. I tried a ‘dutchman’ system, but it gave me problems.
Sometimes simple is the best.
Michael
