SailNet Community - View Single Post - Pocket screws in boat building?
post #6 of Old 01-23-2009
sailingdog
I don't see why you couldn't use them for pieces like tables and such. I wouldn't recommend using them for bulkheads and other structural pieces.
Ideally, if you could find them in Magnesium Bronze or 316 Stainless, you'd be best off using them, but even normal steel would work, provided you sealed the wood properly and took steps to prevent the fasteners from getting wet.
However, I wouldn't use pocket screws to fasten laminated materials together, at least I wouldn't recommend putting pockets into laminated materials—like marine plywood—since I think the pockets are better suited to solid wood. For instance, you could use pocket screws to fasten a marine plywood top to a hardwood table base, provided the table base had the pockets in it, not the top.
sailingdog is offline
