SailNet Community - View Single Post - Pocket screws in boat building?
post #17 of Old 01-23-2009
ronspiker
ronspiker's Avatar
As with any question the answer is 'It Depends'. It depends on what your use is. I do alot of woodworking, cabinets and furniture, so if you are making something like that then yes pocket screws work very well. I would also use a polyurethane glue like Gorilla glue also unless you plan on taking it apart. Another option if you are joining corners is to use dowels and glue, or countersink screws. I would only use screws if you are using SOLID wood. If you use screws in plywood it will delaminate, maybe not at first but over time it will split between the plys.
ronspiker is offline
