SailNet Community - View Single Post - Adding Batteries-Where?
post #1 of Old 01-25-2009 Thread Starter
cruiserdave
Hi all. I've got a question I've been trying to work out and keep coming up blank. I have an O'Day 35 (same as 34 w/swim platform). I need to add batteries for an extended cruise. I current have 4 #27's, 2 located in the factory supplied mount in front of the fuel tank and 2 located in the deep port side locker. Problem with mounting in the locker is the boat lists to port. I plan to add a 5th #27 for starting battery. Has anyone found a place closer to the center to mont these 3 batteries? Thanks.
David
"The hardest way is usually the easiest way."
"All I have to do is............."
cruiserdave is offline
