SailNet Community - View Single Post - Is the 1987 Pearson 39-2's hull balsa cored
post #6 of Old 01-25-2009 Thread Starter
cruisingmom
Well the verdict is in - The Pearson 39-2 IS BALSA CORED BELOW THE WATERLINE
Well, after very careful inspection of the Pearson 39-2 that was sworn to be fiberglass only below the waterline - we found that there is in fact balsa sandwiched between fiberglass below the waterline. This was found after removing the draws under the V-birth and it was clearly evident that along the hull from about 3 feet from the deck joint to the bottom of the hull there is balsa. Most of the rest of the access areas of the boat had carpeting glued to the hull so we could not see the balsa. Only under the V-birth and then by inspecting the sail locker on the port side of the cockpit could we detect the tell tale bulge of the balsa. In the V-birth the squares of Balsa were clearly evident. So - thats the truth of it. Now it will be critical to determine if it is worth pursuing this vessel knowing that Balsa is below the waterline. What do you all think - in 1987 was the technology of manufacture good enough with good owner maintenance to generate a worthy boat with balsa below the waterline?
cruisingmom is offline
