SailNet Community - View Single Post - Bottom Paint Questions
post #2 of Old 01-27-2009
sailingdog
If you're going to be re-barrier coating the boat, you really should remove all the paint IMHO.
The through-hulls should only be painted if they're Marelon. If they're bronze, leave them unpainted.
Replace the soft filler material with either glass or thickened epoxy.
Foam-rubber sanding blocks are good for the leading/trailing edges of the keel, rudder and hull.
Bad prep is usually the reason for paint flaking. Either the surface wasn't cleaned properly or the paint that was on it was incompatible with the new paint and should have been removed.
sailingdog is offline
