Basically, this is to limit the volume/weight of water that the cockpit can contain in the event your boat gets pooped.
JgSteven-
You screwed up your measurements...the units should be CUBIC FEET...not square feet.
I am guessing that your cockpit is 8' long x 4' wide...and the three feet is the height. However, I doubt that is the lowest cockpit coaming level... If the lowest cockpit coaming is 2', the total cockpit volume would be 64 cubic feet, and according to Gui's measurements, you are allowed 55.6 cubic feet, so you'd need to glass in a volume of 8.4 cubic feet. In your cockpit, you could create a bridgedeck expansion locker that was 1.5' x 4' x 1.4' or so.
If you're new to the Sailnet Forums... please read this POST.
