SailNet Community - View Single Post - Faded Black Aluminum Mast
post #2 of Old 05-27-2001
jack_patricia
RGS:
Your mast was most likely iridited, then anodized, and finally painted. That''s the common sequence, anyway. That means you''re really asking what''s the best way to replace or renew the painted surface of the mast. Regretably, the answer is probably to repaint it (mast down, hardware off, proper paint prep, etc.). Long on work, low on expense (the good news) and a great time to take care of all the other little things that suffer from inattention up there. <g>
I''d recommend the International Paints product line: they offer a very good primer, compatible with a good selection of 1- or 2-part paints. I refinished my 3 Bomar hatches (aluminum castings) with their products and found them easy to work with. I used a brush, while you''d want to spray, so you may want to call their Tech line first and have them send you the Tech Sheets for those products.
Jack
jack_patricia is offline
