SailNet Community - View Single Post - Compound for awlgrip
post #2 of Old 02-01-2009
Maine Sail
Maine Sail's Avatar
No..
NO!!! Without getting into too much detail there is no good way to buff or polish Awlgrip. Use only Awlcare applied by hand..
DO NOT use Finesse It II or any machine buffer or you will most certainly ruin the finish. Even pros who are trained in repairing Awlgrip still ruin the this hard shell that protects the pigment layer very often. Once you've burned through this hard outer shell the finish is toast..
Paint jobs are expensive please don't ruin yours.
If you need to clean it Starbrite Black Streak Remover is the best I've found for AlwGrip. Follow the BSR wash with AwlWash followed by Alwcare and it will do wonders.
Do not let BSR sit on any part of the finish for long & do small sections with a microfiber rag then rinse it off and move on..
______
-Maine Sail / CS-36T
Maine Sail is offline
