SailNet Community - View Single Post - Where are all the hybrids?
post #4 of Old 02-02-2009
sailingdog
There are a lot of problems with doing a diesel electric hybrid on a small sailboat at the moment. First, is the weight of the battery banks needed to make the system workable. Second, is the reliability problems with any electrical system you'll find on a small sailboat. Third, is the fact that the technology is still very much a work in progress...so if you do go the diesel-electric hybrid route, you'll basically be a guinea pig.
Also, if you're planning on cruising long-term, you'll have to consider the difficulties of getting the system repaired in remote areas. Parts and such are likely to be far less accessible.
Stick with diesel. It is a solid, proven, mature technology that is relatively simple to operate and maintain.
sailingdog is offline
