I am no expert but I think if the keel bolts allow the keel to flex at the joint there is no putty, epoxy, or adhesive that will prevent a crack from appearing. If the keel bolts are correctly designed and torqued almost any conventional method of sealing the joint will work.
Back in the day, people were opposed to the idea that the world might not be flat.
