  #15 (permalink)
Old 09-11-2004
ct ct is offline
ct is on a distinguished road
Life expectancy of fiberglass?
jbanta:
"I wonder how long your hull would la[s]t in an unprotected state."
Well, according to all estimates, about 40 plus years.
It''s plain to see that you didn''t follow the link I provided in my previous post above. Read it and you will find that aluminum is a far better choice than fiberglass. The only real problem with aluminum is that it doesn''t lend itself to mass production.
jbanta:
"A good epoxy barrier coating and glass is good for YEARS of service before it must be stripped and done again. How about aluminum? How about Steel? I believe you are misinformed about boat building and maintance."
Aluminum does not require any barrier coating whatsoever, therefore it doesn''t have to be "stripped and done again". Aluminum doesn''t require any paint. Un-painted aluminum does form a dull gray oxide coating which I personally don''t like, however there are many aluminum vessels that last for 40 plus years without the benefit of paint or any other coatings.
I won''t address steel as that is not relevent to the discussion of aluminum.
As far as fiberglass vs. aluminum I''m afraid it is you that is "misinformed about boat building and maintance."
