SailNet Community - View Single Post - Diesel Engine won't start
post #4 of Old 02-09-2009
jrd22
Courtney the Dancer
jrd22's Avatar
I'm guessing you have a Yanmar 3gm, but they are all similar. White smoke while cranking can be unburnt fuel, ours did that and we had the injectors rebuilt (and then replaced). That helped the hard starting and reduced the white smoke. Another thing that we have used recently that seems to help is something I read here on Sailnet. Pull your stop cable out and crank for 10 seconds and then push the cable in while cranking, usually fires right up. Hope that helps.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
