Originally Posted by chucklesR
The only issue I see is a) you need to disconnect your bilge pump so it doesn't try to run while frozen
b) you need to find the source, blue chalk helps you to trace water leaks, just sprinkle it on the likely places and see if a water trace runs through it (you can get it in bulk from a hardware store, use the chalk made for chalk lines).
and of course C) your bilge is too small to open a for profit ice rink
d) You need to move somewhere warmer!!!
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
