SailNet Community - View Single Post - Helms 25 Running Rigging Info
post #11 of Old 02-11-2009
jumaggafanny
jumaggafanny's Avatar
I looked for my old source of Sampson on Ebay and failed to find it. I purchased a 600 spool of Sampson double braid. I made all halyards, Main, Jib, stay'sl, Spinnaker and topping lift. I had over 160 ft left over that I use in a 4:1 tackle that when I hoist to the mast head allows me to hoist my bones aloft. I also use this rig to step my mast. I don't have wire to rope on the lines at all.
I've got dim's for the rudder somewhere, I'll start digging. Chimera's rudder is total custom, balanced w/trim tab so it's of no use to pattern, somewhere I have a drawing of original...I'll look.
Is your boat a pop top model? Does your cockpit drain to forward scuppers that are then routed aft beneath the cockpit?
Have you walked/stepped on the foredeck and coach roof looking for potential soft spots? I know of 2 that have suffered some soft core issues that were repaired. I was suspect of any and all fastners wicking water to core, so I drilled em' all. Of over 200 1" dia. holes I found discolored wood core only beneath the stbd. winch. Improper fastening and bedding will allow water to wick down and destroy the boat in stealth mode.
David
jumaggafanny is offline
