SailNet Community - View Single Post - How much winterizing do I need?
post #6 of Old 09-18-2004
Jeff_H
Moderator
Jeff_H's Avatar
Depending on the winter you can expect to have problems with your water lift muffler if you do not winterize it. I typically run antifreeze through the raw water side of the engine until I see it come out the exhaust. With experience I have learned that on my current boat''s 3GM30 that means roughly a gallon to a gallon and a half of water/antifreeze mixture. I have been using a biodegradable engine anti-freeze for the past few years rather than an automotive antifreeze, which technically should not be discharged into the Bay. Most winters you can sail almost every weekend if you are hardy enough. As I mentioned earlier I typically drain and add antifreeze to the water tanks and potable water supply system and flush antifreeze through the head and saltwater supply system.
To touch on the earlier comments, I typically do not tent my boat. We generally do not get enough snow to justify the nuisance of tenting.
Jeff_H is online now
