SailNet Community - View Single Post - generator install exhaust
post #2 of Old 02-12-2009
amarinesurveyor
First post here on this forum.
No. Every engine and generator exhaust should have its' own dedicated discharge port. Potential problems: when runnning both engines you might be causing too much backpressure on the exhausts; when running just the engine or generator, you could potentially be forcing water up the one that isn't running and get water into the cylinders. Plus if you have a survey done for insurance purposes or when selling, the surveyor will call it out and it will have to be fixed. Best to do it right the first time.
Brian
amarinesurveyor is offline
