SailNet Community - View Single Post - Identification Lights & Nav Lights on Sailing Vessels
Old 02-13-2009
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
Originally Posted by soulesailor View Post
Can the red over green be seen further away than the masthead tri-color? What's the benefit?
Depending on how high you mount them, they could be seen virtually as far as the tri-color.
The benefit is that you can use the red-over-green configuration simultaneous with the deck lights (the Nav Regs do not permit use of the mast-top tri-color at the same time as the deck lights.) By using them simultaneously, you benefit from greater over-all visibility.
