SailNet Community - View Single Post - Cockpit table material?
post #16 of Old 02-16-2009
bwindrope
Break, curse, fix, repeat
bwindrope's Avatar
Building a cockpit table myself right now
Hi Faster, I'm doing this same project. Aeolus has some old instrument mounts on the pedestal guard ( I long ago discarded the instruments but kept the mounts just for this purpose) and I'm using those as the base to the Starboard table I'm designing. I'm using Starboard for all the usual reasons, and have had good luck with it in the past. My table will be removed when not in use and will not hinge at all. It will be about 21 X 24 with edge rails to prevent stuff sliding off. It will attach to these old instrument mounts with bolts and washers on top, and a flat piece of stainless underneath providing the clamping effect.
As soon as she is built I'll post picture on my blog. You can get partial Starboard pieces from Defender for cheap enough. I think my mounting situation is too specific to be of much help to others, but the materials choice was relevant so I thought I would pipe up. My table, at that size, doesn't weigh too much I don't think. I used 1/2 inch material. Good luck.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
