I don't recall ever seeing a boat like that with a splice in the spar, so I am wondering if this is the way that the Wauquiez 33 was built, or if this was perhaps a repair or a modification.
So, my questions are:
Is this original construction or a repair/alteration?
Whether original or altered, does this compromise the strength of the spar?
What other advantages/disadvantages are there to this construction?
I honestly don't know a thing about spliced spars, but it did look as if the spreaders are not angled upward properly. Could be the angle of the photo, but flat or downward spreaders are an indication of rig problems and/or an improperly rigged boat. Did you notice the angle of the spreaders?
You'd need to check for that boat. Sometimes the problem is the original location of the factory, or the boat when a replacement mast has to be shipped. Over-the-road trucking had 40-45' length limits and anything longer went oversize at steep cost penalties, so sometimes spars "had" to be shipped in two pieces and spliced.
If the mast is not bendy, and the splice is done properly, in theory it is perfectly good. if the PO or the broker claims they do not know whether this is original--they're either inept or shamming. That's the kind of thing a boat owner and seller really SHOULD know, it they have any grasp about mechanical things on their boat. (You know, like changing the oil, charging the batteries, pumping the bilge.<G>)
The splice is likely original, as many older masts that would be over 40' were built in two sections.
Related Threads
1.7M posts
173.8K members
Since 1990
