Old 02-18-2009
erps's Avatar
erps erps is offline
the pointy end is the bow
Some engines allow you to bolt on different size pulleys, a small one for your water pump, a big one for your alternator. The pully on our MD17 that runs the primary alternator must be 10 to 12 inches in diameter. Even then, I run the motor at a high rpm when its putting out the amps to reduce belt wear. I don't know how hard it would be to modify your bracket to switch to a small case single foot alternator. Perhaps you could borrow one and see how well it matches up?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
