SailNet Community - View Single Post - Anchor Trip Line 101, Please
post #29 of Old 02-19-2009
AdamLein
AdamLein's Avatar
My guess, looking at the buoy/ring thing in erps' link, is that the idea is to get the ring as close to the anchor itself as possible.
Say you have a 25 lb anchor and, I dunno, 100 feet of chain at (I'm making numbers up) 1 lb/ft. You take the bitter end of the chain, stick it through the ring, and -- gulp -- drop it overboard. Not mentioned, but I expect it would have to go into a bag or something.
Suppose the anchor is fouled in 20 ft of water. You keep pulling the chain through the ring and into the bag and eventually you have 80 feet of "bitter end" on one side of the ring in a bag, which weighs 80 lbs, and 20 ft plus a 25 lb anchor on the other end. The 80 lb bag is now a counterweight that, along with the buoyancy of the ring buoy, is sufficient to lift the 45 lbs of chain and anchor out of whatever it's stuck in. The closer you can get the ring to the anchor, the easier it gets.
What your anchorless boat is supposed to be doing at this time is not clear to me.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
