Old 02-19-2009
scottyt scottyt is offline
scottyt is on a distinguished road
best bilge pump switch
okay i want/need a new float switch for my bilge pump. i dont want the built in ones due to cycling. i currently have the west marine float, which is giving me problems, it drops down the ball inside moves ( i hear it click ) but it does not shut off about 1 out of 10 times. now if i give it a tap it clicks again, it does not do this all the time, but it killed my battery ( as in need new battery it was cold out ). yes i know i need to fix my shaft seal, ordering that at the same time. the worse part is my hunter has a bilge about 4 inches deep so it fills pretty quick ( as in with no pump about a week )
what does anyone think about the sensor ones like this
Water Witch Bilge Pump Switch
or
Ultima Bilge Pump Switch
i am starting to wonder about the float type, i had rule that went bad, now this one is acting crazy. i want to know if anyone has had problems with the above type? also has anybody found it to draw too much juice when just sitting there? are there any better types out there ?
