SailNet Community - View Single Post - Battery Re-design question
post #15 of Old 02-22-2009
sailingdog
KindOfBlue
You'd be much better off using all eight T105's for a house bank and setting up a small starting battery. Then connect all the charging sources to the big house bank and use an echo charger to charge the starting bank. The eight-bank house setup will actually give you more run time than it did when it was two four-battery house banks, since the Peukert factor goes down.
sailingdog is offline
