Originally Posted by Keldee
How often do you check your rigging?
Obviously not often enough.
Our water here in Pamlico Sound is only a little bit salty- not even enough to taste. It varies a little depending on wind direction and if there has been rain lately, but, on the whole, we don't have any of the real salt water problems you see closer to the ocean.
My inclination would be not to use any kind of treatment other than to hose off obvious salt deposits with fresh water and let things air dry.
There was a tiny little spec of rust at the very end of the cable where it broke. I don't think anyone who is not a professional rigger would have spotted it on casual inspection.
I think the only way to prevent this sort of thing from happening is to know the age of your standing (and running) rigging, and to replace it regularly. How often that would be depends on your location and how you use your boat. BFS enthusiasts like me probably need to do it more often than most. Your local rigger or sailmaker would probably be the one to ask.
