SailNet Community - View Single Post - High Density Poly
Old 02-22-2009
JHJensen's Avatar
JHJensen JHJensen is offline
Marine: Educator,Surveyor
JHJensen is on a distinguished road
Send a message via Skype™ to JHJensen
Lightbulb Kick up rudder self lube washers....kitchen cutting mats.
Originally Posted by davidpm View Post
I just made a rudder out of wood for a dinghy. The rudder is designed to go into a box like affair so it can kick up.
I'm thinking that a super large washer of HDP maybe 1/16" think and 3' diameter would make it work smoothly and give it a lot of support.
Any idea where to find hdp or nylon sheet material to make it from?
David,
Go to a kitchen supply, hardware or even your grocery store and get one of these very thin cutting mats. Trader Joe's here in Fairfield had them for a while. They are come in sets of three... less than five dollars. I am headed over to TJ in a bit and will see if they are there and get the exact name for you.
These are not the self healing cutting mats used by picture framers and model builders.
I use them on the boat and keep a couple in my travel bag. You can cut them with shears or a utility knife. You application does not require thickness but larger surface area. They are great for many uses.
In googling them I found the following link which is fun! Audio Cookbook » Blog Archive » Wobbling a Plastic Cutting Mat
I have used these mats cut into strips as glides for companion way hatches as well when they are fiberglass on fiberglass.... I am not sure what the plastic is but nothing sticks to them.
John
"It's not just about the vessel... more importantly it is about the people, their safety and their vessels in that order. "(PFJ 1952-1986)
