N33 pulls to port under power
I am looking at buying a Newport 33. When under power she seems to pull excessively to port. The broker says, "Don't worry about it, its normal. Due to prop wash." Which I could understand. However, I have found the sellers broker to be less than credible on several issues. As a result, if he told me the sky was blue and the sun was out, I'd check twice myself before believing him...
If I had to put a number on it - I would guess the pull would measure a constant 3 to 4+ lbs on the wheel - measured at its outer edge when running at about 2500 rpm, maybe about 6 kts.
The boat comes with a Navico WB5000 autopilot. However it does not appear to ever have been used. The belt is too big for the setup. But I wonder if it would work under power with that constant pull to port.
Anyone familiar with the range of expected pull to port on a N33?
Rich McManus
