SailNet Community - View Single Post - A/B switch for removing shut from battery circuit
post #2 of Old 02-23-2009 Thread Starter
patrickstickler
Rhumbunctious
patrickstickler's Avatar
Would it be possible to protect the shunt by switching in a short across the shunt (i.e. "path of least resistance"). E.g.
Normal usage, shunt inline:
Code:
                                       Gnd
            |-------[Off]--/   /--------|
           (-)----- Shunt --------------|
House Bank (+)---------(+) FuseBox (-)--|
                  [A]---(+) Engine (-)--|
Starting Batt (+)--|                    |
Emergency start, shunt shorted:
Code:
                                        Gnd
             |-------[On]----------------|
                   [b]---(+) Engine (-)--|
Starting Batt  (+)                       |
So, normally, engine switch (A/B/Both/Off) is on A (starter battery) and shunt bypass switch is off.
For emergency start, engine switch is on B (house battery) and shunt bypass switch on, providing direct path to ground around shunt.
If a man speaks at sea where there is no woman to hear, is he still wrong?
Cruising the Baltic in 'Merihiisi', a 1979 Westerly Berwick Ketch
patrickstickler is offline
