SailNet Community - View Single Post - Replacing Cutlass Bearing
post #1 of Old 02-23-2009 Thread Starter
SeaDeucer
Hey Sailors, I'm a happy new owner of a Jeanneau (Attalia 32 '85). However I have been told to replace the cutlass bearing. This appears to be a problem as the suggestion includes checking the shaft of course. However the shaft is way too long to come off without removing the rudder. In speaking with a mechanic, he suggested sliding the engine forward. Although there is great access to the engine on this model, actually moving it forward, and probably up and into the cabin seems a little excessive, to say nothing of expensive. If there is play between the shaft and cutlass bearing, is it likely the shaft is damaged? Any comments would be appreciated, thanks, Philip
Last edited by SeaDeucer; 03-08-2009 at 11:02 PM. Reason: problem solved, please delete
SeaDeucer is offline
