SailNet Community - View Single Post - Portable Generator
post #8 of Old 02-24-2009
Look in a used chandlery.... lots of different chargers because there are people out there that have to have the latest. You can pick up a good 250 amp charger for $75- $150. Duo Gen makes a great water/wind generator. A little pricey but if you are under sail it will give you 8 amps at 6 kts, 14 amps at 7 kts and 20 amps at 8 kts if you can go that fast. When you'r in port flip it up out of the water and switch the water propeller to the Wind propeller and you are still generating the power. Stay out of the doldrums!
GeminiDaze is offline
