SailNet Community - View Single Post - Replacing Cutlass Bearing
post #4 of Old 02-24-2009
If you are a new owner of a '85 boat did the recommendation come from the survey when you bought it. If so I hope you considered that in the price. I have a 2002 Jeanneau SO43DS... my strut is bolted through the hull. If you cannot get the shaft out without removing the rudder or engine, I suggest removeing the strutt and replacing the cutlas bearing then re-installing the strutt. While it is out of the water, make sure you do a bottom job. Round trips hauling the boat will run $200 - 500 depending on the part of the country your in so you might just as well take care of everything on the bottom... check for blister also.
Good Luck
GeminiDaze is offline
