SailNet Community - View Single Post - Solar Product Review
Old 02-24-2009
Valiente's Avatar
Valiente Valiente is offline
SD...I'm still getting used to these concepts. I'm looking at 4 x 130W Kyocera panels or equivalent plus a 24V Air-X wind turbine that I would transform down to 12 V before it went into my charge circuit. My house banks will be circa 840 AH in 4 x 8D lead-acids and these will feed into Xantrex echo chargers, one to a single start battery and the other to a battery in the forepeak for a 1200W Lofrans windlass. The charger/inverter (already purchased) is a Xantrex RS 2000 and I have a Honda EU2000 as a tertiary backup/power tools on deck portable genset.
Could the Outback (which sounds appropriate) MPPT handle BOTH charge sources simultaneously and how does the dump/diverter relay deal with this? I have the impression that a heat sink is involved, and I would rather not have that down below, unless I could use it heat hot water!
I'm not trying to hijack the thread so much as expand it, because your answer will illustrate the function of MPPTs in a well-designed alternative charging system.
Can't sleep? Read my countdown to voyaging blog @
