SailNet Community - View Single Post - No engine power
Thread: No engine power
post #4 of Old 10-16-2004
Yodagwb
No engine power
Agreed. I would change the filters first and see if that corrects the problem. If it does then go after the fuel and find out what is causing the clog. If not, then move on to the injectors. If you pull them and take them to be tested make sure you keep the holes in the motor clean and protected.
Yodagwb is offline
