Old 02-25-2009
k1vsk k1vsk is offline
k1vsk will become famous soon enough
If you are referring to a rub strake on the stern and it covers a transom/hull joint, you have a problem - can't tell from the pics and don't know what type boat this is so can't be sure.
Is there a joint there? If so, the only good way to fix it is remove the rubber and clean and re-seal the joint. If water gets out, it can most definitely get in too so do a good job.
