SailNet Community - View Single Post - Toe Rail Issues
Thread: Toe Rail Issues
Old 10-18-2004
pjfsail pjfsail is offline
pjfsail is on a distinguished road
Toe Rail Issues
Steve, Jim aboard the Argo is absolutely correct and I will attempt to elaborate on his advice. I use West Systems for all my fiberglass/epoxy repairs. Gougeon Brothers Inc. sells a small repair manual for $2.95 titled, Fiberglass Boat Repair & Maintenance. The publication number is, 002-550. This is an excellant help for a number of fiberglass repair problems. I purchased mine from West Marine. Chapter 7 deals with Installing Hardware. I am going to quote from this manual. "Apply an epoxy/404 or 406 filler mixture, thickened to peanut butter consistency.... Inject or use a mixing stick to fill the fastener''s holes with the thickened mixture."
So, to sum up, I use West Systems 105 Resin, 205 Hardener and either 404 or 406 Filler. The resin is mixed with the hardener to a 5-to-1 ratio (it is advisable to purchase the measuring spouts when you order the products, makes is SO MUCH EASIER) and then the filler is added to this mixture. You add a little at a time and mix until it looks like peanut butter. Once you have it mixed, either put it into a syringe (you can buy these when you purchase the other items) or shove it in the holes with a mixing stick. I prefer to use a syringe. I use lacuer thinner and acetone for clean up. I find the best place to buy West Systems is from www.pyacht.com, the reason: they are the least expensive, don''t charge you and arm and leg for shipping, and will ship immediately. I''m not sure if you can buy the manual from them, but you can get it from Gougeon Brothers at www.westsystem.com or call (989)684-1374. I hope this will help.
Peter restoring Soaring Eagle
