SailNet Community - View Single Post - Cost for Bottom Paint Job
post #2 of Old 02-28-2009
sailingfool
ASA and PSIA Instructor
Depends on what you expect to be done. You don't want to paint the bottom unless it needs the paint, i.e. there isn't enough on already to last until the next haul. Less ablative paint is better than more. Your bottom may need:
1. No paint at all.
2. Touch up on low spots where a base coat is showing.
3. Touch up and one full coat.
4. If the existing paint is flaking off, strip the bottom to gelcoat or barrier coat, paint with one coat of base paint , then two coats of top paint. this is a very expensive job.
A two year old boat should not have too much paint on it, so you shouldn't need to strip paint. Touch up and one coat should be cheap, in boat terms, I would think $400-500 plus paint, although it's been 7-8 years since I had a yard paint my bottom. Again, don't paint unless you know you need it.
sailingfool is online now
