Last minute charter in BVI''''s
John,
Since you obviously have significant experience in VI chartering and are recommending a US based start, I''d be interested to hear your thoughts on a couple of questions. I''m assuming since you own a boat in charter you researched the differences between USVI and BVI starts. The trip I outlined above was our first and only (but not last) VI charter.
1) You mentioned flight availability. For our trip airfare for our family (4) was the biggest single expense. A quick look on orbitz this am did not reveal any significant price diff between St. Thomas, US and Beef Is. BVI from Tampa, FL. I realize this stuff changes all the time, but have you found in your experience that flights are any less expensive to US VI than British? Is there a departure fee for leaving St. Thomas as there is from EIS?
2)When you sail from St. Thomas, do you stay in the US or do you travel to the BVI as well?
3)Related to 2: If you go to the BVI do you need to check in and out, and if so what is the "hassle factor" involved? Do you then need to check back into the US?
4)Provisioning for us was tedious. As I mentioned before, next time I''d make more extensive use of the online service we used, and that will help, but still I found prices much higher than I read to expect and selection to be about what I''d read to expect (somewhat limited). How would you compare USVI vs BVI for provisioning?
I enjoyed the charter we did more than any other sailing I''ve done and would happily repeat it as done, but I''m certainly open to options that could improve it even further.
Thanks for your time.
Brian
