SailNet Community - View Single Post - Small hole completly aft at waterline
post #23 of Old 03-02-2009
JohnRPollard
Moderator
JohnRPollard's Avatar
Originally Posted by Wayne25 View Post
Yes John, that's what I was thinking. Those old holes may be stripped out or slightly oversized now and would need potting to get a good bite.
Yeah, could be. If so, it would definitely serve to fill with epoxy then re-tap after it has cured. If there's coring, it should be done no matter what. Heck, it wouldn't hurt a thing to fill with epoxy then re-tap these holes regardlesss.
But I didn't get the impression that Bene505 was having any difficulty with the rubrail mount. I.e., the rubrail had not shown signs of being loose or not well set on the hull-to-deck joint. My impression was that it was more a question of the fasteners being a bit too long for the job and not adequately bedded. So I was just focussing on the simplest solution. Also, I usually give a lot of deference to the factory guys.
I guess we'll have to hear from Bene as to whether there are any other issues in play here.
JohnRPollard is offline
