I see a problem with what you propose. Filling the fresh water tank might be difficult without enough height drop from the fill hole to the tank. If the height is too shallow or if the hose is not sloped downhill enough the water will "back-up" in the fill line not allow the tank to fill.
If you switch the hose for the deck fill you will want to replace the deck fill hose over to the sanitary system type of hose. If you can't get to the deck fitting from below deck you might be able to unscrew the deck fill from above and then pull the hose out to disconnect.
